Valve Springs Changed...
Old Sep 13, 2004 | 09:51 PM
S8ER95Z's Avatar
Any break in methods? I hear you have to heat cycle them. Thanks in advance.
Also the engine hasnt had oil in it for a long time (has been out of the car for 6+ months and was shipped from texas dry) ...Anything I need to do to prime the oil pump and ensure it has enough lubrication? I put the oil in from both sides..allowing the rockers to be soaked in it as I was pouring. Just looking for things to make my life easier. LOL
Old Sep 14, 2004 | 06:30 AM
rskrause's Avatar
Moderator
Re: Valve Springs Changed...
No break in needed for valve springs. Just put plenty of oil on them before startup.
Rich
Old Sep 14, 2004 | 09:11 AM
S8ER95Z's Avatar
thanks.
Old Sep 14, 2004 | 11:18 AM
WS6T3RROR's Avatar
i thought i read on comps website something about cycling them too. where you keep them under 2500 rpms and let the motor hit op temps. then let it cool and repeat. once more maybe. i dunno maybe i dreamed it up bit i think i remember seeing that.
Old Sep 14, 2004 | 11:27 AM
92rslt1's Avatar
yea there is some degree of break in needed. basicaly dont run it around hot for hours. its not realy that big of a deal. just run for a few short period of time let them heat and cool a few times and your good.
Old Sep 14, 2004 | 03:56 PM
S8ER95Z's Avatar
Ill probably drive it home, park...drive to my friends house..chill there for a while...maybe make a couple passes on 2nd st and head home again..should be good enough I think. thanks for the replies everyone.
Old Sep 14, 2004 | 03:58 PM
S8ER95Z's Avatar
Originally Posted by 92rslt1
looking for springs for a 306 and roller rockers!!!
Btw...Combination Motorsports
EX-612s
http://www.cmotorsports.com/93-97-fb...ine-valvetrain
Fit stock heads and installed easy as hell.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
