Which Valve Springs?
Old Jan 17, 2005 | 02:45 PM
99BlackTA's Avatar
Need a good set of valve springs to throw in the car when I install the 1.6 pro magnum rockers in a few weeks. I need them to be good with the stock cam but also able to handle a CC 305 in the near future. Will the 918's be a good choice for an LT1 car?
Old Jan 17, 2005 | 03:34 PM
Z28Nut's Avatar
Re: Which Valve Springs?
I went with Comp 981's, but I was pressed for time because the 983s Comp says fit don't ( I.D. too small for stock spring seat ). I did Comp ProMag RRs at the same time on stock cam. Picked up .7 on the 1/4 with springs, RRs, MAC mids and ORP w/cutout. HP peaked at 5100rpm on old springs, haven't had a chance to get it back on a dyno with the new parts to see how far up they moved peak HP.
Old Jan 17, 2005 | 03:50 PM
Loadre's Avatar
612 package from Combination Motorsports.
Old Jan 17, 2005 | 04:33 PM
99BlackTA's Avatar
So the EX-612-16 package will work fine with the STOCK cam and 1.6 rockers for now and then be able to hold up to a CC 305 with 1.6 rockers also? I just want to go ahead and upgrade the springs with the rockers now so I don't have to touch them again when the cam install comes around.
Old Jan 17, 2005 | 04:35 PM
99BlackTA's Avatar
This is from the Combination Motorsports website...
EX-612-16 EX Components 612 Single Coil Extreme Performance Valve Spring Kit-fits stock head without machining, includes lightweight retainers and locks $109.97
Old Jan 18, 2005 | 07:23 AM
Kreinmc's Avatar
I have the 612 springs with my 1.7 rockers and a stock cam and I am getting valve float real bad starting at 5800rpm. I have some much better springs on the way. Crane 10308 spring kit. I used these springs on my 306 and they worked great. You can get the kit for 147 bucks at summit. Do it right the first time!
Old Jan 18, 2005 | 09:37 AM
Compstall's Avatar
K-Motion K800's.
Old Jan 18, 2005 | 09:47 AM
Loadre's Avatar
612s with 224/230 and 1.6 rockers and having no problems.
Lloyd uses these springs on his LE1 packages which spin to 6200 with a CC305 ish cam.
Kreinmc, have you checked for correct pushrod length?
Old Jan 18, 2005 | 10:25 AM
truedualws6's Avatar
If you decide on the beehives here is the parts list.
26918 springs
795-16 steel retainers (10*)
or 794-16 titanium retainers (10*)
614-16 locks (10* +.050")
4705-16 spring seats
When installed on stock LT1 aluminum heads you
should end up with a 1.75" installed height. Check
out Speed Engineering in the supporting vendor page
for prices. Click Here
Old Jul 15, 2005 | 01:16 PM
AlwaysCode390's Avatar
Question Re: Which Valve Springs?
Is that crane 10308 kit strong enough for the 306 cam, has anyone else used this setup?! Here are the specs on summit:
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.460
Spring Rate (lbs/in): 408
Inside Diameter of Outer Spring (in): 1.075
Inside Diameter of Inner Spring (in): .803
I am looking for an easy replacement and this setup says that there is NO machining required.....which is FANTASTIC!!! Thanks for the info---
Old Jul 15, 2005 | 01:47 PM
BUBBA's Avatar
Crane 99893-16
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
