valve springs
Old Oct 18, 2004 | 06:06 AM
blazzinbird's Avatar
valve springs
i need a pair of valvesprings that are good up yo a .600 lift. what brand would you recomend. also need a price. and where to get them. this is for the gm 847 cam.
thanks in advance
Old Oct 18, 2004 | 06:29 AM
teke184's Avatar
Re: valve springs
comp cams 918s
available through most of the site vendors. got mine at thunderracing.com for $140 i think
just installed them last week.
Old Oct 19, 2004 | 10:33 AM
TransAmGT94's Avatar
Re: valve springs
www.cmotorsports.com or call them and ask at 1-702-798-8504
Old Oct 19, 2004 | 11:03 AM
madwolf's Avatar
Re: valve springs
You will be pretty close with a valvespring good to .600 lift and an 847 cam. (if you plan to run 1.6 rockers that is)
K-motion k-800 springs would be an option.
Old Oct 19, 2004 | 02:12 PM
dmoor88's Avatar
Re: valve springs
do you want a set that simply drops in to the stock seats or will you have the seats worked over on the heads?
Old Oct 19, 2004 | 03:26 PM
dragonz28's Avatar
Re: valve springs
I'm using CC987 and they drop right in and are good up to 600lift.
Old Oct 19, 2004 | 04:06 PM
dmoor88's Avatar
Re: valve springs
arent 987's the double coil that require machining?
Old Oct 20, 2004 | 09:51 AM
dragonz28's Avatar
Re: valve springs
I didn't machine mine i just dropped them in with the old locks and retainer. I'll dig around and see if I have the box to make sure I got the part # right. I did springs and rr at the same time aout 2 years ago.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
