valve springs
Old Jun 8, 2004 | 07:55 PM
94TA_LT1's Avatar
valve springs
what springs do i need with the cc305 and 1.6 rockers. also, do i need retainers too?
Old Jun 8, 2004 | 09:10 PM
94TA_LT1's Avatar
ttt
Old Jun 8, 2004 | 10:17 PM
SStrokerAce's Avatar
You need retainers and locks. Maybe shims and seats if you have some springs. E-mail me and I can hook you up with what you need.
Bret
Old Jun 8, 2004 | 10:21 PM
RamAir95TA's Avatar
Re: valve springs
Like Bret said, you will need springs, retainers, locks, and seats. Crane makes a kit (p/n 10358) that includes 1.46" diameter springs (99893), retainers, locks, and seats. I would recommend against using the seats that come in the kit, since they are flimsy and do not locate the spring in the pocket. Comp makes a seat (4770-16) that does a much better job.
The Crane springs are good for .600".
Old Jun 8, 2004 | 10:22 PM
94TA_LT1's Avatar
thanks guys
Old Jun 8, 2004 | 11:34 PM
formula383's Avatar
So the Crane's would be a good setup if the shims are not used?
Does any additional work need to be done to get the springs to work with those seats?
I am getting ready to buy some valve springs and haven't been able to decide which ones to get yet. But I don't want to machine the head to get them to work.
Old Jun 8, 2004 | 11:51 PM
94TA_LT1's Avatar
yeah...i was wondering that too
Old Jun 9, 2004 | 02:05 AM
WS6T3RROR's Avatar
the crane kit is nice but those springs are kind of heavy for a rr only engine. the parts bret will sell you are probably a much better match and will be better suited for the job. every time i've dealt with him he always picks the best setup for the money when required. what he'll sell you will be the best lightest wieght parts for the money. as poorly understood as valvesprings are in general i have to say go to a pro for your parts its all they do every day.
Old Jun 9, 2004 | 06:33 AM
Don 97 SS's Avatar
They will fit in oem LT1 heads. As mentioned above, the Crane .015" seat shims that come with the kit are kinda whimpy. But if you use a .060" thick seat locator (and most are about that thick) you will be adding considerable seat spring pressure. These are good springs and are rated at about 400lbs an inch. So just be mindful of that.
I have this combo.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
