Valve spring specs
Old Nov 6, 2006 | 02:51 PM
geut's Avatar
Valve spring specs
Hello,
Can annyone give me the specs of a stock valvesprings that are used in the 1994-97 Z28 equipped with rollercam ?
Thank's
Gr.
Dieter
Old Nov 6, 2006 | 04:13 PM
seawolf06's Avatar
http://www.grandsportregistry.com/lt1vslt4.htm
Just says 85lbs, which I'm guessing is seat pressure. If you upgrade the RR or cam, you need to change these.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
