Valve spring selection
Old Nov 18, 2008 | 10:26 AM
cause4panic's Avatar
I need help choosing a set of valve springs.
Stock cam
1.6 roller rockers probably going crane gold or a set of jesel shafties
Figure 10 psi of boost
edit: stock 100k+ mile lifters
Would the lt4's work? Or should i got with the crane 10308 kit ?
Old Nov 18, 2008 | 11:05 AM
MTBSully's Avatar
i would go with the cranes, so you have more room for valvetrain upgrades in the future. Im going through the same thing, and im not sure if im gonna hafta change out all my springs because the previous owner put in springs that were only good enough for the cam that was currently in there. Do it once and be done with it
Old Nov 18, 2008 | 11:13 AM
Whenever i get around to doing the heads (LE or AI) i will let them set up new springs to match their cam. So do it once do it right does not really apply to the springs.
The rockers i do have that mentality with, leaning towards the shafties.
Old Nov 19, 2008 | 07:28 AM
NightTrain66's Avatar
these springs will drop right in and work for you . . .
http://competitionproducts.com/prodi...p?number=98213
Lloyd
Old Nov 19, 2008 | 07:57 AM
What retainers and locks should i go with to fit the COMP Cams 1305-16 rocker?
Thank you
Lloyd
Old Nov 19, 2008 | 08:23 AM
those can be used with the stock locator, locks and retainers.
Lloyd
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
