Valve spring & rocker suggestions?
Old Mar 16, 2004 | 01:16 PM
94DROPTOPZ28's Avatar
I have a completely stock LT1 and my valve springs are going bad and I was wondering what are a good set of valve springs & rocker arms to go with? I might upgrade the cam in the future but not at this time, so I would want valve springs that are good enough so when & if I decide to change the cam they will be good enough. Thanks for the input.
Old Mar 16, 2004 | 01:25 PM
CeeBee94Z's Avatar
Re: Valve spring & rocker suggestions?
Well to be honest that all depends on what type of cam you plan on going with....
Old Mar 16, 2004 | 02:21 PM
Probably nothing too much bigger than a hot cam since emissions is a big problem here...
Old Mar 16, 2004 | 02:42 PM
Compstall's Avatar
Well, if you're sticking with a hotcam, then use hotcam springs. If you go with a cam any bigger than that, get some different springs. I wouldn't use hotcam springs for anything other than a hotcam.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
