valve spring r&r
Old Feb 2, 2008 | 06:26 PM
nader454's Avatar
valve spring r&r
I'm doing my homework now, I need to now how much air pressure is required to hold up the valve while replacing the springs. My concern is that too much pressure may roll the crank off tdc, and obviously not enough, and the valve will fall.
Old Feb 2, 2008 | 06:38 PM
96capricemgr's Avatar
How about none. Bring the piston to TDC and the valves can only fall a small amount and you can get the springs without fussing with air.
Old Feb 2, 2008 | 06:42 PM
nader454's Avatar
ok...sweet, thanks
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
