Valve spring question: need help
Old Jan 20, 2005 | 01:20 PM
ajschult's Avatar
Ok, I am having my heads ported and rebuilt. I am going with ferrea 2.05 1.60 valves. I am going to go with a custom cam similar to the 847. Does anyone have any recommendations? What factors go into picking out the right set of springs for a given application?
Old Jan 20, 2005 | 01:53 PM
camaroKid223's Avatar
Re: Valve spring question: need help
for my 847 im going to go with kmotion k-800's seem like a spring that can really take some rpm's and its still priced well
Old Jan 20, 2005 | 03:04 PM
ajschult's Avatar
ttt
Old Jan 20, 2005 | 04:57 PM
OldSStroker's Avatar
The person specing the custom cam should know all the specifics of head flow, engine size, rpm range, driveline, gears and your desires for the combination. He should also spec the springs and other valvetrain bits you'll need. If you are getting the custom cam from the head porter (like Lloyd Elliott), he'll spec the springs, etc.
If you aren't going that route, you might give it serious consideration.
My $.02
Old Jan 20, 2005 | 05:20 PM
ajschult's Avatar
I really do want to go with the LE3 setup, but I'm not sure if I will be able afford it and purchase lifters, injectors, gaskets, tune and labor for the install. I realize thats a great price for a proven set up, I am just on a fixed budget.
Old Jan 20, 2005 | 06:36 PM
1racerdude's Avatar
You don't need lifter's.The stock ones will take you past where you wan't to go.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
