Valve spring lift question???
Old Jan 23, 2006 | 01:40 PM
NstyLT1's Avatar
Quick question... How do you determine what the maximum lift is on valve springs with 1.6rr....Is there a formula for it or could someone briefly explain it to me.. Thanks guys....
Old Jan 23, 2006 | 01:43 PM
stroked383z28's Avatar
Re: Valve spring lift question???
You take your installed height minus coil bind minus 0.050 = max lift
Old Jan 23, 2006 | 01:57 PM
MyShibbyZ28's Avatar
You don't find max lift for a spring with 1.6 rr's, you find the max lift of the spring (doing it how it was stated above), then you take your camshaft lift (assuming the listed lift is with 1.5, since most list it with that) and divide that number by 1.5 (that's your current ratio), then times it by 1.6 (that'll be your new ratio with 1.6 rr's), and the new number needs to be lower than your max spring lift.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
