Valve spring help and opinions
Old Jan 14, 2004 | 10:42 PM
speedracer93z28's Avatar
i am going to swap out my valve springs i have 1.6 rr's. ok i know i need the spring compressor (which did you use and how well did it work?), valve seals, and the springs, retainers, and locks. am i missing anything. i also would like to know what springs you would recomend for my setup. i will most likley get springs that support .600 lift, is that too much?. and one last question, how long did it take you guys. thanks a lot.
Old Jan 15, 2004 | 09:05 PM
Bud M's Avatar
If you are staying with the stock cam, LT4 springs are fine. Super stiff springs will just accelerate wear.
I used the KD spring compressor. The job took me half a day, including clearancing the valve covers.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
