valve spring compressor
Old Jul 22, 2004 | 11:23 PM
tagz's Avatar
Question valve spring compressor
Which valve spring compressor do you guys use? I found one at pep boys, it looks like a pair of locking plyers (red handle) and squeezes like a plyer. Problem with that was it did not hold the inner valve spring.
I am told the pry bar tool is very nice, linked below. But i am concerned with it fitting under the cowl towards the rear of the engine. Has anyone ever used this?
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
Old Jul 22, 2004 | 11:38 PM
Re: valve spring compressor
That's the old simple type compressor. Don't see how that is going to fit under the cowl.
Old Jul 22, 2004 | 11:39 PM
tagz's Avatar
yeh didn't thing so. looks pretty simple for the other valves though.
Old Jul 23, 2004 | 02:55 AM
Compstall's Avatar
I used a basic screw-style spring compressor with no problems, and I did the job with the heads on the car. I think it cost a whopping $20. Even works on dual valvesprings (which I used on my motorcycle).
Old Jul 23, 2004 | 04:17 AM
97WS6SCharged's Avatar
I used one that looks like a big c clamp with an air hose hook up. Very cool, I was done in like 15 minutes. Course I did my springs with the heads off the car in a shop.
Old Jul 23, 2004 | 05:18 AM
Don 97 SS's Avatar
I highly recommend the Moroso spring compressor for about $80. It is the best and easiest to use. It will work with dual springs and will work with the heads on the engine in an f-body. I own three different types of spring compressors and the Moroso is far superior design.
Old Jul 23, 2004 | 06:44 AM
teke184's Avatar
check these guys out
the compresser does two at a time
Old Jul 23, 2004 | 06:56 PM
96capricemgr's Avatar
http://www.mytoolstore.com/kd/kdengi13.html#3271 I used a tool much like the 3271 shown here worked great, not sure if it would work right with dual springs.
Old Jul 23, 2004 | 10:20 PM
tagz's Avatar
bought the 3271 today from napa, and it does not work with the dual springs . no one else near me sells them
Old Jul 26, 2004 | 04:27 PM
1fastlt1's Avatar
Crane has one just like that, that just came out a little bit ago. Jegs has them listed for $105
Crane Spring Compressor
Old Jul 26, 2004 | 05:12 PM
Alex94TAGT's Avatar
I personally used a $30 screw-type compressor from O'Reilly's -- with the heads still on the car (like what 96capricemgr posted). I honestly dont know how else you can reach the rearmost springs. However, since mine kept slipping off of the inner spring (I installed dual valvesprings), I simply modified a large washer to sit on the longer arm of the compressor -- which would then reach-thru to hold the inner spring better. Worked just fine for me, though there may be better methods.
The compressors posted by Teke and 1fastlt1 look like a snazzy idea. Too bad it's so expensive -- that'd make the install process go considerably faster.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
