Valve Spring Choice please help!!!!
Old Aug 8, 2004 | 07:49 PM
TransAmGT94's Avatar
My first plans were to go with a cc306 cam so i purchased ex612 springs from cmotorsports these i was told are good for .600 lift I changed my mind and went with a custom grind from cc and the lift on the intake is.606 so i was thinking about upgrading my springs to a .650 please help with part numbers and sites where i can get these the cheapest with out modifying the heads if possible and the cheapest place for 30lb injectors would be helpful too these are the only two things i need to start on my cam swap
I also need to know how much HP the stock fuel pump can support cause im sure ill have to replace that too!
What Suggestions do you have for an after market pump
Old Aug 9, 2004 | 10:46 AM
Re: Valve Spring Choice please help!!!!
Any body have any ideas i would really like to get this project under way
Old Aug 10, 2004 | 11:24 AM
Does anybody have any ideas? I would really like to get started on install so i can have fun in it before winter hits
Old Sep 8, 2004 | 09:46 PM
92rslt1's Avatar
get any answers yet??.. if not ive been told the stock pump can handle 450hp. as for the spring you should call combination back up to see which ones they can recomend somtimes you can get offset retainers too.
thanks
Old Sep 9, 2004 | 02:12 AM
S8ER95Z's Avatar
As explained to me by bbrannen@compcams.com Brian at Comp Cams..you can use LS1 Behives *springs arent necessarly made for LS1 only* Shoot him an email or call him (directly) 1-800-365-9145 ext 558. He gave me a good price and offered suggestions. Im sure he can help you figure out what you need.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
