Valve Seals?
Old Nov 29, 2008 | 10:33 AM
meissen's Avatar
Question Valve Seals?
Hey guys,
Seems like a silly question, but figured I'd ask just to be sure...
I went to Murrays, a local auto store, and asked for LT1 valve seals. He gave me flat o-rings. When I started taking the heads apart, I realized the stock heads have the umbrella guides.
So what do I do with these flat o-rings? Do I put the o-rings on first and then press the umbrella guide over it?
Here's some pictures from Summit as reference...
What I purchased looks like this:
http://store.summitracing.com/partde...0&autoview=sku
What are in the stock heads, obviously, are more like this:
Old Nov 29, 2008 | 11:11 AM
Stl94LT1's Avatar
Take them back, they are not used on LT1 heads.
Old Nov 29, 2008 | 11:27 AM
meissen's Avatar
So I definitely need these umbrella guide seals?
Old Nov 29, 2008 | 11:38 AM
Stl94LT1's Avatar
I use the "Viton" style seals.
Old Nov 29, 2008 | 12:22 PM
MachinistOne's Avatar
Neither one of those seals is correct for this application, and even on the old stuff I set them up to use modern metal clad viton seals.
Looks like this:
Old Nov 29, 2008 | 12:23 PM
rednblack94z28's Avatar
Old Nov 29, 2008 | 12:30 PM
meissen's Avatar
Thanks for the guidance! What would be a good viton style seal? I have stock valves, not sure what the diameter is. Would prefer no machining, also...
A search of Summit shows:
http://store.summitracing.com/egnsea...=KeywordSearch
Which one would be the best recommendation?
I remember someone mentioning Edelbrock seals in another thread, would these be sufficient?
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 29, 2008 | 03:49 PM
Stl94LT1's Avatar
Take your O-rings back to Murray's and get the Felpro Vitons.
Old Nov 29, 2008 | 03:59 PM
meissen's Avatar
Thanks for the help!
Old Nov 29, 2008 | 04:30 PM
JasonK94Z's Avatar
The Felpro ones from Autozone, etc. are the ones you want. They work great for a oem replacement.
Old Nov 29, 2008 | 06:26 PM
The problem is that many of the old timers working at a parts house will think you mean the original LT1 and give you the umbrella/o-ring combination. If they pull it up by application, felpro has the seals that work - they are nitron not viton.
Old Nov 29, 2008 | 07:31 PM
meissen's Avatar
Awesome, thanks for the help guys! I can't wait to get this all done - going from a stock 3.4L v6 to an LT1 with a cc503 should be fun!
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
Catmaigne
Jul 14, 2015 05:17 PM
camaro02DK
Jul 5, 2015 09:24 AM
