Valve seal size question
Old Oct 12, 2004 | 01:39 AM
DuronClocker's Avatar
What size positive valve seal should I use for LT1 heads?
I have a set of 11/32" x .562" here that I bought for my old 305 heads, but since I've decided to swap in the new motor, I'm not going to bother putting these seals on the old heads. Will these seals work well on the LT1 heads? I've seen people say that the .530" seals require machining of the guide bosses, and the only sizes I saw available at the time were .500", .530", and .562", so I'm assuming these are the correct sizing, no?
Old Oct 12, 2004 | 08:45 PM
arnie's Avatar
Re: Valve seal size question
OEM is .56" guide O.D. However, OD may not be concentric with I.D. For that reason, it is adviseable to turn the O.D. of the guides to .53" to true then up with the valve stem.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
ChrisFrez
Jan 25, 2015 08:06 AM
Jazsun
Dec 29, 2014 12:14 PM
