Valve question
Valve question
If you take a look at this picture you can see that the valve on the right is sort of protruding more below the head surface than the one on the left, it's not obvious but I can see the difference with my eyes, is this something to be concerned about or not??
http://user.tninet.se/~xus275f/Bilder/valve_out.jpg
(the heads are used but have not been run anything yet after being ported, milled and new valves, not done by me.)
Thnx.
Thnx.
Have you had those valve seats replaced for the larger 2.02 valves. The largest valve you can go and get to seat correctly on the stock head is going to be a 2.00. I'm thinking that's your problem, but I may be wrong.
Fastbird93: Yep, they should be.
FireAm94: ok....
I just wanted to know what you thought, seems cind of odd to me but I've never looked at a set of LT1 heads with valves and springs before so I couldn't compare and so on...
Thnx.
FireAm94: ok....
Thnx.
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
