Valve Covers, How much taller for T&D Shafts?
Old Jun 29, 2004 | 04:24 PM
ddr698's Avatar
How much taller over stock do valve covers on an LT1 have to be in order to clear T&D shaft mount rockers? Any info appreciated, thanks,
Dan
Old Jul 2, 2004 | 01:07 AM
TCAL95Z's Avatar
Hi,
Just noticed your post. I have some of these on order.
Did you find anything out and what do you plan to do with your alternator?
Old Jul 2, 2004 | 03:12 PM
TCAL95Z's Avatar
Anyone??
Old Jul 3, 2004 | 06:09 AM
speedmiser's Avatar
TTT
Id like to know as well...
Old Jul 3, 2004 | 08:26 AM
Mindgame's Avatar
Guys, you don't need much more height than the stock valve covers have to clear a shaft setup.
Check with B&B Fabrication ( 732 )364- 6700
They make a really nice aluminum cover that is 5/16" taller than stock. They also stock the passenger side cover with alternator clearance.
These covers cleared a Crower shaft setup on a C4 Corvette. The only problem I can see is maybe clearance along the inner sides of the cover. Not something that couldn't be fixed but some rockers that aren't profiled at the "tail" might have a problem. Of course Jesel offers tail-profiling as an option but the amount of actual clearance is going to vary brand to brand.
If you find you need a bit more height, gaskasinch a couple of cork gaskets together and maybe get longer bolts.
edit:
Flatlander Racing carries B&B's stuff.
-Mindgame
Old Jul 5, 2004 | 11:12 AM
TCAL95Z's Avatar
Thanks Mindgame,
you have a lot of info about these cars
I really don't want to relocate my alternator
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
