Valve Covers, How much taller for T&D Shafts?
How much taller over stock do valve covers on an LT1 have to be in order to clear T&D shaft mount rockers? Any info appreciated, thanks,
Dan
Dan
Guys, you don't need much more height than the stock valve covers have to clear a shaft setup.
Check with B&B Fabrication ( 732 )364- 6700
They make a really nice aluminum cover that is 5/16" taller than stock. They also stock the passenger side cover with alternator clearance.
These covers cleared a Crower shaft setup on a C4 Corvette. The only problem I can see is maybe clearance along the inner sides of the cover. Not something that couldn't be fixed but some rockers that aren't profiled at the "tail" might have a problem. Of course Jesel offers tail-profiling as an option but the amount of actual clearance is going to vary brand to brand.
If you find you need a bit more height, gaskasinch a couple of cork gaskets together and maybe get longer bolts.
edit:
Flatlander Racing carries B&B's stuff.
-Mindgame
edit:
-Mindgame
