Valve Covers
Old Apr 10, 2006 | 04:23 PM
BarneyMobile's Avatar
Valve Covers
Where is the best place to find Valve covers to clear RR's. I have the comp pro magnums. also what color do you guys think would look good. I hear chrome is pain to keep clean but I still want something to make it look like I have some work done under the hood.
Old Apr 10, 2006 | 04:42 PM
omaha stylee's Avatar
Re: Valve Covers
ebay always has the tall valve covers with the notch for clearancing the alternator
Old Apr 10, 2006 | 04:52 PM
2000GTP's Avatar
Re: Valve Covers
Unfortunatetly, there isn't the greatest selection of aftermarket valve covers for our cars. But as mentioned above, ebay would be a good start. I just purchased a pair of chrome valve covers off a board member for 60 bucks. Whatever you do find though, you may have to grind your alterator a little bit in order for it so sit in its proper location with the addition of aftermarket valve covers.
Old Apr 11, 2006 | 09:50 AM
OBE1 95Z28's Avatar
Re: Valve Covers
The stock valve covers can be modified to clear the CC Pro Magnum RR's. Cut the support between the centerbolt tube and the intake side of the valve cover. Leave the lower support in place to hold the tube in place.
Old Apr 11, 2006 | 10:17 AM
wrd1972's Avatar
Re: Valve Covers
I have the same RR's you have and it takes less than 2 minutes to do the mod with a pair of slip joint pliers, just flatten out those ribs. Piece of cake.
Old Apr 11, 2006 | 01:01 PM
ejfagala's Avatar
Re: Valve Covers
I clearanced a set of the e-bay covers, they will not fit is stock form. THe problem is not the height but rather how wide the trunions are.
Here is a shot of my covers modified
Old Apr 11, 2006 | 01:17 PM
turbo_Z's Avatar
Re: Valve Covers
I like the LT4 composite valve covers. They look clean and supposidly eat up valvetrain noise.
Old Apr 11, 2006 | 01:40 PM
wrd1972's Avatar
Re: Valve Covers
Yup thats true, but they dont clear the altonator or som I was told.
Old Apr 11, 2006 | 09:42 PM
96trans am's Avatar
Re: Valve Covers
Yeah I bought some off ebay about a month ago. They were polished aluminum and knotched for the alt. I stil had to do a lot of cutting to the supports to make them fit. I figured it would have already been done. Also the hole was in the wrong spot. It was in the back instead of the front which will make it a PITA to fill it with oil.
Old Apr 11, 2006 | 11:39 PM
bt96ss's Avatar
Re: Valve Covers
I have the LT4 valve covers on my Camaro. They fit fine and clear rockers without modification. On my TA I powder coated the stockers black and modified them as the above post says, They fit the Promags perfectly.
Old Apr 12, 2006 | 08:26 AM
Stoopalini's Avatar
Re: Valve Covers
I put the LT4 covers on a few months ago, and they clear the alternator just fine. They were a drop in cover, and required no modification at all to clear the Scorpion 1.7 RR.
If they'll clear the Scorpions, I guarantee you they will clear just about any rocker arm out there (the Scorpions are huge!)
Thomas.
Old Apr 20, 2006 | 06:21 PM
Z95m6's Avatar
Re: Valve Covers
Could you get a better picture of the underside of those covers? Yours is a little blurry. It looks like you only have to clearance one side of the cover or did you have to trim both sides of the cover?
Old Apr 20, 2006 | 07:32 PM
93camaroLT1's Avatar
Re: Valve Covers
I bought these one's:
http://store.summitracing.com/partde...5&autoview=sku
Think they look sweet as hell, kinda wanted them for a while and the upgrade to pro-mags was justification enough for me to spend $150 on valve covers, lol. Still need to grind the alternator a bit to get them to fit tho.
Old Apr 20, 2006 | 09:11 PM
JustAnotherGuy's Avatar
Re: Valve Covers
yeah i looked at a pair of them at a local shop.. look very nicley made.. i just could not part with 150 bucks to have pretty valve covers
Old Apr 20, 2006 | 09:30 PM
Z95m6's Avatar
Re: Valve Covers
I don't think those covers will work with out really cutting the back of the alternator for them to clear.
