valve covers
Old Apr 2, 2003 | 05:24 PM
Max 93's Avatar
valve covers
what are my options for valve covers? I want some chrome or polished aluminum that will clear the alt.
Old Apr 2, 2003 | 05:45 PM
MZK4252's Avatar
Racenent has a set of aluminum VC's for like $150 and chrome for $50 (I think). I can't say that they were fast getting them to me, but they had what I wanted. I got the polished aluminum ones, they're super smooth, BTW! And they do clear the alternator and in fact give you a little more valvetrain clearance.
Old Apr 2, 2003 | 06:14 PM
Brent94Z's Avatar
Super Moderator
These are LT1 Granatelli valve covers...
http://www.bfranker.badz28.com/misc/valvecovers1.JPG
Old Apr 2, 2003 | 07:18 PM
Max 93's Avatar
do you have any pics of yours? I can't find a pic on their site.
Old Apr 2, 2003 | 10:57 PM
MZK4252's Avatar
They should be in the mail. Sorry about the low qulaity pics, but I just snapped 'em a minute ago.
Old Apr 2, 2003 | 10:59 PM
Max 93's Avatar
thanks
Old Apr 2, 2003 | 11:02 PM
Deadcarny's Avatar
i tried to order the ones from IRS/racenet last year and they said they were discontinued......they may have picked up another manufacturer since then. however, when i ordered them they told me it would be like 6 weeks. i did not mind since i was goping to play inm the desert for 8 weeks anyway. but after i did not have them in 7 weeks i called and they said they had been discontinued. they had had no intentions of calling and telling me this! i ended up buying them from a place called seco performance for cheaper.
Old Apr 3, 2003 | 12:46 AM
MZK4252's Avatar
Yeah like I said I was not impressed with their speed. However they were on point as far as emailing me to let me know that they would be delayed, and when to expect them. If you can get them somewhere else, give it a try...but I liked the Racenet ones better than any of the others I found.
Old Apr 3, 2003 | 12:56 AM
kgkern01's Avatar
Why can't we use regular center-bolt valve covers, will they not fit the heads or is it just because of the alternator mount? I've seen some chrome center-bolt valve covers pretty cheap and was wondering if I could use them or would waste my money.
Old Apr 3, 2003 | 12:57 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i now have a sig! yay!!
Old Apr 3, 2003 | 12:58 AM
frmula1's Avatar
edited!
Old Apr 3, 2003 | 01:29 AM
Wild1's Avatar
I received a set of chrome covers as a gift. The difference is that they will chatter on the alternator, so I had to beat in the corner with a ball peen hammer and a bag. It clears now. But I can see where the alternator could "knock" on the valve cover and may cause false knock. So, if you do use non-LT1 valve covers, be sure to beat them in good on the side and measure for clearance.
Old Apr 3, 2003 | 01:33 AM
kgkern01's Avatar
So they will fit, i just have to mod the pass side for the alternator bracket? Cool. What about the PVC tube and the oil cap, will the PVC fit and do I just have to go with a breather for the oil filler?
Old Apr 3, 2003 | 02:03 AM
Wild1's Avatar
I went to the local auto store and got the standard oil caps with rubber inserts. The PCV can use the original rubber grommet but I grabbed a fresh one for a couple of bucks at the store. The screw in cap won't work on the covers I have. Not sure if the one you're checking out is the same. But you can get the oil fill caps at any store.
Old Apr 3, 2003 | 08:03 AM
Max 93's Avatar
how much beating do the regular ones need to clear the alt? I don't like the thought of bending up brand new parts.
