valve cover removal (easiest way)
Old Jan 4, 2007 | 03:22 PM
mrmint69's Avatar
I removed the 4 bolts on the passenger side and it is not coming out without removing more stuff. What is the fastest way? My manual says to raise the car and remove the transmission tube and then alternator, alt bracket and i think the egr and air tube. I just want to check for a bad ticking from that area.
Old Jan 4, 2007 | 03:38 PM
Javier97Z28's Avatar
Moderator
Remove the alternator and the valve cover will come off. No need for all that in the manual, although I no longer have any emissions equipment i don't recall it being in the way.
Old Jan 4, 2007 | 03:54 PM
Look at the EGR components photo on Shoebox's website. The tranny tube and the EGR tube should not be a problem.
http://shbox.com/1/egr1.jpg
If you still have the AIR piping, it may be in the way, though:
http://shbox.com/1/diverters.jpg
Old Jan 4, 2007 | 05:06 PM
z275plus's Avatar
U can take all of the bolts out of the alt and just loosen up the bottom one.
Pull the alt over as far as it will go then snug the bottom bolt to hold it in place. Valve cover will come off easy after that.
Old Jan 5, 2007 | 08:17 AM
MadaSnik84's Avatar
I still have all of my A.I.R. components and I had to remove the check valve on the passenger side to get the valve cover off and had to loosen the tube that screws into the manifold on the drivers side and rotate it out of the way.
I too was in search of a tick from the rear of the passenger bank - probably exhaust but figured I'd remove improper valve lash from the list of possible causes.
Old Jan 5, 2007 | 10:04 AM
OBE1 95Z28's Avatar
Also look along the valley between the valve cover and the intake. Wiring harnesses and hose clamps can get in the way and cause the valve cover to hang.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
ModdedNerd
Jan 29, 2015 07:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
