valve cover breather???
Old Feb 8, 2004 | 09:19 PM
1FASASZ's Avatar
i just bought aftermarket valve covers and im deleting my pcv valve or whatever that thing is that goes into the pasenger side valve cover. i was wondering what to do with that open hole, do i stick a valve cover breather in it? do i cap it? and what about the otherside do i stick a breather in that side also?
my freind told me that breathers will make me loose horse powerand that i should use a crank case breather or something.
does anone know what that is? he said you can use the smog pump and hook it up as a crank case vacume
Old Feb 8, 2004 | 09:38 PM
SlickBlack Z's Avatar
I had a valve cover breather for a while...It cut my gas mileage almost in half. I put the stock breather hose back on...gas mileage went back to normal. Something about unmetered air in the system. Sucks cause it sure did look cool.
Old Feb 8, 2004 | 09:41 PM
95BlackTA's Avatar
I have one...city I get like 14 MPG running rich in my auto..and got up to 22 on highway. But im also modded, not stock.
Old Feb 8, 2004 | 10:17 PM
FacelessZ's Avatar
They're more for an appearance mod than performance. On a lightly modded car it's pointless to have a breather...it offsets the air compression as stated earlier...
Old Feb 8, 2004 | 10:25 PM
SVT Killer LV's Avatar
gee maybe if i take my breather off and put my pcv system back on my car I will get 40 mpg with my h/c/i lt1
The stock PCV system is a good system.
Old Feb 16, 2004 | 10:35 PM
1FASASZ's Avatar
first you put down the stock pvc system then ou say it is good. so wich is it
Old Feb 16, 2004 | 10:59 PM
simple's Avatar
i read on www.turbobuick.com along time ago about VC breathers
and the consensus was that on boosted cars they were a good thing and NA cars there is really no gain to be had and in some cases can be "harmful"!?!
i have no real info about it tho and thats the farthest i ever read about them.....
Old Feb 17, 2004 | 01:23 AM
listen northern nevada *** the stock system is fine, however for me it wasn't an option. I also wanted the engine bay cleaner, by getting rid of it, there are less lines... I don't think that the breather is hurting me.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
