Valve Adjustment Question
Old Oct 1, 2004 | 10:20 AM
25th_Trans's Avatar
Question Valve Adjustment Question
I have the Pro Mag lifter part number 875-16. No instructions came for how much preload. I called today and they told me 1/16 turn cold and it would be good, well that was too loose and so was 1/4 turn. Anybody know if 1/2 turn will hurt anything.
Old Oct 1, 2004 | 11:48 AM
slopokrodrigez's Avatar
Re: Valve Adjustment Question
Did you give them time to pump up? No 1/2 turn is normal.
Dave
Old Oct 1, 2004 | 12:07 PM
25th_Trans's Avatar
just checking, didn't want to mess anything up. Comp Cams said that 1/2 turn would be too much
Old Oct 1, 2004 | 12:39 PM
Fastbird93's Avatar
1/2 turn on Comp R's is too much. Do a search, there were a couple of recent past threads documenting this.
Stick with the suggested pre-load that comp recommends.
Old Oct 1, 2004 | 04:38 PM
96LT1TX's Avatar
yes, do you have stock lifters? For stock lifters 1/2 is about right... but if you have comp-r lifters then you should only go a max of 1/8 I have heard, and had best luck w/.
Old Oct 1, 2004 | 07:39 PM
25th_Trans's Avatar
I have the Pro Magnum Hydraulic Roller Lifters. Here is the link to the website that I bought them from: HALFWAY DOWN THE PAGE
Like I said, they didn't come with specific instructions on how much preload. Plan on working on this tomorrow.
Old Oct 1, 2004 | 10:59 PM
12SCNDZ's Avatar
I went 1/8 turn past zero...3000 miles ago...Still no chatter, and I haven't touched them since.
Frank
oldschool
Feb 9, 2016 09:21 PM
warmeck
Feb 2, 2015 12:44 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
