Vacuum Reading with Cam
Old Oct 7, 2005 | 12:33 PM
plan Z's Avatar
If you put a cam in your car how much of a drop should you have in vacuum? mine is at 11hg right now and im trying to find out why its so low. replaced the pcv valve already and i dont hear any air leaking. im troubleshooting transmission problems (not shifting right @WOT).
Old Oct 7, 2005 | 12:57 PM
rcmtby11's Avatar
Re: Vacuum Reading with Cam
i had big vacuum problems when i put my le1 cam in. the biggest problem was valve adjustment. eentuall;y had to adjust em with the car running and now ive got 15-16 "hg
Old Oct 7, 2005 | 01:05 PM
turbo_Z's Avatar
You should see 14-16 inhg with that cam. Try readjusting the valves and how certain are you the cam was installed correctly?
Old Oct 7, 2005 | 07:39 PM
plan Z's Avatar
would having the valves adjusted too tight create the lower vacuum or too loose? and what exactly do you mean about the cam being installed correctly? everything went smooth when we did the cam. its been running fine. thanx,
ryan
rideordie
Nov 5, 2019 04:52 PM
armedtrigger
Feb 24, 2015 08:30 PM
NewsBot
Dec 24, 2014 11:05 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
