Delteq and DIS-4 HO Ignition Box questions...
I currently have a Delteq ignition and I'm now looking into getting a DIS-4 Ignition, mainly because the newer "HO" model allows for better timing control with a DIS. I'm wanting to better control timing for when I add a turbocharger to my Camaro in the near future. Does anyone know how to wire one of these (DIS-4) into the LT1's harness? Does it splice into the GM harness, or would it involve splicing into the Delteq harness...or maybe both??
Re: Delteq and DIS-4 HO Ignition Box questions...
Originally Posted by SGFuryZ
No clue? Anyone?? Should I try posting this in another subforum???
you will also need 4 of MSD P/N 8870 DIS coil adapters, since the DIS-4 needs to be wired in between the module and the coil
It will require no cutting of any stock or delteq wires as the coil adapters will wire directy to the MSD DIS-4. Each coil will have 4 wires running to the MSD box. My page has and picture of the delteq installed with the coils.
http://memimage.cardomain.net/member...38_65_full.jpg
Jason
Jason
