vacuum hose
Old Sep 27, 2009 | 05:35 PM
turnerracing354's Avatar
vacuum hose
i need to replace the vacuum hose that goes from the valve cover to the throttle body, do i need to get the exact hose or will a straigt piece of hose work and is how does it hook to the valve cover just the rubber gromet cause i have oil on my throttle body
Old Sep 28, 2009 | 05:29 AM
Any hose of similar inside diameter will work. There should be a plastic elbow that pushes into the grommet in the top of the valve cover, and the hose pushes onto the plastic elbow.
Its not actually a "vacuum" hose. Is supplies air from in front of the throttle blades to the valve cover, so it can be pulled through the crankcase by the PCV valve vacuum. It isn't unusual to find a bit of oil in the hose of the throttle body, but an excessive amount may indicate heavy blowby on the rings. When the PCV valve can't handle the volume of gasses produced by the bottom end of the engine, the pressure will blow the vapor through the valve cover, where it entrains oil droplets, and into the throttle body.
Check the PCV valve to make sure its working.
Old Sep 28, 2009 | 05:39 PM
I think it was more oil than it should be, if the pcv was bad it would def make the car idle bad when it warmed up right, and would it set a DTC code
Old Sep 29, 2009 | 05:14 AM
No DTC for a faulty PCV system. Wouldn't necessarilly make it idle bad. Sounds like you may have excessive blowby. Time for a leakdown test.
magman
Apr 15, 2016 03:08 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
