Vacuum with a 383?
Old Aug 26, 2005 | 11:10 AM
93z383's Avatar
Vacuum with a 383?
Any one running more than 15 at idle (1000) in a 383, I have lt4 cam and stock heads.
Old Aug 26, 2005 | 02:29 PM
Kraest's Avatar
Retired
Re: Vacuum with a 383?
You should be running nearly stock vaccuum with that setup since that cam is extremely small like Asian weener.
Mike
Old Aug 26, 2005 | 03:07 PM
turbo_Z's Avatar
Yeah with a 383 hotcam idling at 1000 rpm Id think you should see at least 18".
Old Aug 26, 2005 | 04:04 PM
93z383's Avatar
What are the likly causes of a 3 " drop in pressure and what is the easiest way to identify the culpret.
Old Aug 26, 2005 | 09:02 PM
1racerdude's Avatar
Valves to tight,burnt valve,vacuum leak on a hose or module,worn rings.
ak95ta's Avatar
My 383 with the hotcam pull an easy 18" of vacuume. Sometimes even more. Something as simple as rocker arm adjustment cam effect vacuume.
magman
Apr 15, 2016 03:08 AM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
