vaccume line on optispark?
Old Apr 22, 2011 | 10:22 PM
twistedbowtie's Avatar
Question vaccume line on optispark?
my 95 camaro z28 6 speed want start im thinking its the opti
i just replaced the heads gaskets and now it want start i was looking a a diagram of the optispark and it shows some kind of vaccume line running from the opti spark to the intake manifold. could this be keeping my car from starting? thanks
Old Apr 22, 2011 | 10:40 PM
Re: vaccume line on optispark?
The vacuum line won't keep it from starting. Have you checked the basics (spark and fuel)?
Old Apr 22, 2011 | 11:15 PM
yea it has fuel and the stark is intermiting so im guessing i needto replace opti spark.
Old Apr 23, 2011 | 12:47 AM
rv93's Avatar
all the vacuum line does is suck water out of the opti, making it last more than a month.
Old Apr 23, 2011 | 11:07 AM
RamAir95TA's Avatar
The vacuum lines primary purpose is to purge ozone gas, not to remove moisture.
Old Apr 23, 2011 | 11:35 AM
but the car should start without them pluged up.
thanks guys i have one more question, i noticed where the coil wire plugs into the top of the opti (kinda under water pump) where the plug wire goes over the cap the there is a good sized chip out of the plastic cap could that be causeing my spark problem?
thanks again
Old Apr 23, 2011 | 11:47 AM
Open the hood, in the dark, with the engine running, and look for arcing in that area.
Old Apr 23, 2011 | 11:52 AM
okay thanks ill try that. i heard something arcing the other day but didnt hear it anymore so thought i was hearing things. that could be it
Old Apr 23, 2011 | 01:00 PM
While you are at it, make sure the vent/vacuum system for the Opti is hooked up correctly. As noted in the posts above, not having it connected will not prevent the Opti from functioning, but not having it connected can cause a shorter life for the Opti.
Shoebox has photos of the vacuum harness and the connection locations on his website. Compare against that info.
z28cam1993
May 20, 2015 10:56 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
