uummmmmmmm...................
Old Oct 6, 2003 | 10:35 AM
  #16
crAzy95z28's Avatar
oops.sorry i meant mallory coil!!! i called oreilly and they have a mallory coil fo rmy car? should i get that..it is high performance or should i just keep calling unitl i find a MSD?
Old Oct 6, 2003 | 11:11 AM
  #17
95BlackTA's Avatar
Go to www.thunderracing.com and buy one of their coils. I have the cheaper red one(MSD I think)..works just dandy. Thunderracing has great customer service too.
Old Oct 6, 2003 | 11:49 AM
  #18
revtime's Avatar
I have an Accel that came with the 300+ ignition box and it has been very good.
Old Oct 7, 2003 | 12:58 AM
  #19
GA93FORMULA's Avatar
In addition to the ignition coil, wires, and module checks; what is the fuel pressure? Can you hear the fuel pump running? Check PCM grounds. Check all the easy stuff like fuel, ignition, and PCM related fuses and go from there. Good Luck.
Old Oct 7, 2003 | 02:06 AM
  #20
crAzy95z28's Avatar
fuel pump turns on just fine....what do i look for in the ground wires and stuff?
Old Oct 7, 2003 | 02:43 AM
  #21
NVetro's Avatar
Get the MSD blaster coil for your car from thunder racing, it works great As for your ignition control moduel, its located right above the coil on the same bracket, make sure the connector is all the way in, take it out, and put it back in (you'd be surprised haha) If that is not it, I would check your plugs and wires before i go out and spend $ to get FP tested. Checking plugs/wires is free if you do it If that checks out, and it holds presure then look into your pcm grounds. Pull out PCM slightly and make sure the connectors in the back are in secure. Get back to us and tell us if any of that worked.
Old Oct 7, 2003 | 02:53 AM
  #22
crAzy95z28's Avatar
ok..where in the hell is the PCM module.....sorry havent had any problems with that so i really dont care about the pcm..but now i have to...where is it? ill do all this stuff in the morning...also this only happens with the car mostly in the mornings and at night..during the cool air im guessing.....sometimes afte been sitting fro about 3-4 hours!!!
