Using a valve spring micrometer?
Old Jun 7, 2007 | 10:04 PM
2QUIK6's Avatar
Anyone know about using these at the bottom of the page here
http://www.thunderracing.com/catalog...vid=4&pcid=109
I had read a post, can't find it now about someone using a micrometer like this I beleive and got the measurements 0.15 off because they did not allow for something?? So when the micrometer read 1.85 it was really at 1.70 and then caused spring bind.
Does this ring any bells or is it straight forward with these?
Old Jun 7, 2007 | 10:27 PM
2QUIK6's Avatar
I think I found my answer in this post
http://web.camaross.com/forums/showt...ghlight=spring
Old Jun 7, 2007 | 10:32 PM
Boosted_Z28's Avatar
So you will have proper seat pressure and to avoid coil bind, the micrometer measures installed height of the valve spring. If the height is greater than it should be, then a shim(s) is placed under the spring to get you close. I say close because shims are only available in a couple of thicknesses. Unless you don't have the retainer installed properly when checking the installed height, or you are reading and/or using the micrometer incorrectly, it is a pretty straight forward. Obviously you will have needed to do the math properly to ensure you are installing the springs at the proper height in the first place.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
