Using Total Seal - Quick Seat powder on new engine
Old Aug 28, 2007 | 09:41 AM
camaro81's Avatar
Has anyone ever used this stuff? I figurd I'd give it a try since it's supposed to speed up ring seating. I knew it was gonna come in a small container, but I swear it looks like it's less than half full
Is one little 2 gram container enough to do all 8 cylinders?
Old Aug 28, 2007 | 12:36 PM
Kevin Blown 95 TA's Avatar
I used it on my engine last time. There are past threads on it. Anyway, it seems to have worked since I don't have any blowby, and didn't even have any when the engine was green. It's important to really clean the cylinders well and then rub it in till they seem to have a greenish tinge to them. I still have enough left to do another engine or two - it didn't take much to do all 8 cylinders.
Old Aug 28, 2007 | 03:26 PM
seawolf06's Avatar
When would you use this to seat them? Is it only on certain applications or would any motor benefit from it?
Old Aug 29, 2007 | 11:53 AM
SStrokerAce's Avatar
Yes any motor will benefit from this, it helps show you how to clean the bores properly which is one of the keys. It does work really well to make sure your rings break in, nothing like doing a tear down because you don't beat on it enough to break in the rings.
Bret
Old Aug 29, 2007 | 11:58 AM
Colin91Z's Avatar
I've used it on my last two LT1 builds. No complaints from me. And one of those little containers did both motors, and I bet I have enough left for another one too.
If you clean the bores good enough, that stuff will give the bores a greenish tint. It's kinda weird looking, but at least you'll know that you applied it properly
Old Aug 29, 2007 | 01:17 PM
seawolf06's Avatar
How much and where can you get this? Don't mean to hijack the thread, but it seems your question was answered.
Old Aug 29, 2007 | 02:09 PM
Colin91Z's Avatar
http://store.summitracing.com/partde...0&autoview=sku
Old Aug 30, 2007 | 08:32 AM
camaro81's Avatar
I know your supposed to install the pistons with the rings dry, but do you put any oil on the piston skirts when you install it or does the quickseat serve as a lubricant for the skirts as well? I figured if I oiled the skirts it would interfere with the quickseat as I was turning the motor over during assembly, but I wasn't sure.
Thanks for the informative replies I actually did do a search on the subject, but all I found was a few threads where quickseat was meantioned. I couldn't find where it had been discussed before.
Old Aug 30, 2007 | 09:22 AM
Colin91Z's Avatar
Yes the Quickseat is the lube, don't put any oil on the skirts. Install them dry.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Roadie
Feb 16, 2015 10:34 AM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
