electric water pump
Old Aug 27, 2007 | 11:39 PM
asia517's Avatar
electric water pump
I just decided to go with an electric water pump for my lt1 I have already mounted it to the old water pump but I am now trying to find a block off plate for the hole in the timing cover, does anyone know if one is made for this or do I have to make it myself, also I'm missing some bolts for the rebuild ( timing cover, rear main, and some others) where should I go to get them?
Old Aug 28, 2007 | 12:48 AM
henryz28's Avatar
For the timing cover I took the cover down to Autozone and found a freez
that was close.The plug was a hair two big so I grinded a little off the cover than put some blue silicone on the freez blug and beat it into the cover.For the bolts I have a place by my house called bolt king and they have almost every bolt.
Old Aug 28, 2007 | 12:51 AM
Romero155's Avatar
i wouldnt block it off, just let the drive spin freely so that way you could always put the stock water pump back on without having to take the timing cover on. Just make sure you take out the waterpump drive coupler.
Old Aug 28, 2007 | 09:30 AM
asia517's Avatar
ya its too late for that...
Old Aug 28, 2007 | 11:00 AM
97FormulaWS-6's Avatar
I used a freeze plug like was already said, but I know others who have either welded a piece of aluminum in, or JB welded a piece in; I've even seen a quarter JB welded in to block the hole!!!
Old Aug 28, 2007 | 04:37 PM
jeepbeast's Avatar
i actually jb welded a half dollar in the hole. worked like a charm, no leaks!!
Old Aug 29, 2007 | 06:15 AM
user 647483's Avatar
You'd be surprised how common that trick is LOL
Old Aug 29, 2007 | 07:11 AM
That's because finding the "right" freeze plug is very hard. Luckily I have a good reputation with the local parts store so I got to go in back and rifle through ALL the plugs to find one that fit.
Old Aug 29, 2007 | 10:13 AM
izzyz28's Avatar
That's what I used and it's been working fine for 65,000 miles. Surprisingly my water pump has lasted that long as well.
Old Aug 30, 2007 | 12:19 AM
BlakeW5's Avatar
Ok, just asking because I don't really know for sure, but if you do install an electric wp do you have to plug the hole? I've been thinking about getting one just because I haven't done anything to the car in years and I'm kinda getting an itch for a little more hp to spice things up.
Old Aug 30, 2007 | 09:32 AM
asia517's Avatar
you could just let the drive spin freely or block it off blocking it is more common.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
