Using Starter to set Valve Lash?
Old Dec 5, 2007 | 12:05 PM
  #16
FASTFATBOY's Avatar
Originally Posted by B-Rad420
FASTFATBOY would that setup work on stock lifters and comp rollers? I need to spin my motor over a few times to get the lifters to pump up before hand correct? Brad
Yes it would work, I would do the zero plus 1/4 turn to get it started. Then once it warms up and then cools off a little redo them if need be.
David
Old Dec 5, 2007 | 08:55 PM
  #17
SS RRR's Avatar
Originally Posted by FASTFATBOY
My thinking was with the lobe being more aggressive(steeper) wouldnt that make for more base circle?
David
Having a more agressive lobe profile equates to a narrower base circle especially for small base circle camshafts. I'd much rather use that for a base adjustment and fine tune valve adjustment using the bump start method.
Old Dec 5, 2007 | 09:01 PM
  #18
FASTFATBOY's Avatar
I will do it the 90* method from now on, adjust "X" cylinder and rotate 90* according to firing order....just hard on my old arms with the 30 inch pull handle on the crank bolt LOL.
David
Old Dec 5, 2007 | 09:30 PM
  #19
SS RRR's Avatar
Why not do the bump start method with a remote trigger switch? I use that now and will never go back to manually turning the crank unless I have to.
Old Dec 5, 2007 | 09:57 PM
  #20
MeanGreen97Z's Avatar
How much do those remote trigger switches go for? I get tired of getting under the car and turning the crank.
Old Dec 5, 2007 | 10:27 PM
  #21
SS RRR's Avatar
Maybe $10... You should be able to pick one up at any parts store.
Old Dec 5, 2007 | 10:54 PM
  #22
B-Rad420's Avatar
I am gonna go check O'Reilys this weekend and see if they have one. Or actually screw that. I just need to find a push button that can handle 12 volts and hard wire it in like some of you guys have done. Also wanna put some kinda switch going to a starter wire so I can flip it from inside the car and no one can crank my car to steal it. Since I have 4 cars right now I can only afford liabilty only on them considering I am 23 and work at a hobby shop, lol. Brad
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
thenewkid
Nov 29, 2014 04:54 PM
