Using smog pump for vac. pump(shoebox)
Old Sep 21, 2003 | 06:42 PM
LPE Z convt's Avatar
Arrow Using smog pump for vac. pump(shoebox)
Is it possible to use the smog pump for a vac. pump ? Just run the out let to a bung in the exhaust and the inlet side to the pcv on the intake? your thoughts .. Thanks Will this solve low vac. problem?
Old Sep 21, 2003 | 06:50 PM
kevmor99's Avatar
I don't think the air pump is that powerful...
Old Sep 21, 2003 | 06:57 PM
I was wondering that ..... Thanks for the reply
Old Sep 21, 2003 | 07:45 PM
Re: Using smog pump for vac. pump(shoebox)
I don't think I would do it the way you described and I doubt that it will work for that particular use. The motor could probably not take it. You could always do some testing with it if you have nothing else to do.
Old Sep 21, 2003 | 08:28 PM
BES-383's Avatar
This thread has some good information for you. All you have to do is search .
http://web.camaross.com/forums/showt...threadid=82357
Old Sep 21, 2003 | 09:27 PM
Well, since he said he wanted it to solve a low vacuum problem, I thought he wanted it as additional vacuum to run accessories like the brake booster, not an evac system that other thread was talking about.
Old Sep 21, 2003 | 09:44 PM
Using the AIR pump to pull a vacuum on the intake manifold, and then dumping the air into the exhaust system makes no sense at all. You might slightly increase vacuum under some condtions, but you would be pulling air out of the intake manifold that has already been measured by the MAF sensor, and is intended for combustion. At WOT, you would effectively be stealing airflow from the intake runners.
And, dumping air into the exhaust would completely screw up the O2 sensor readings, making the engine run pig rich.
Or did I miss the point of your question?
Old Sep 21, 2003 | 09:47 PM
Thanks shoebox you are on the right track
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
charchri4
Apr 14, 2015 06:40 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
alphaauto
Jan 23, 2015 07:42 AM
Dark Angel
Aug 8, 2002 08:43 AM
