Urgent OptiSpark questions
Old Jun 14, 2004 | 05:57 PM
WhiteLightningZ's Avatar
Well the car started to run rough and backfire the other night which I thougt was due to a few burnt plug wires. I replaced the wires and then the car wouldnt even start. It just cranks. So then I thought it might be the optispark cap and rotor so I replaced those and still no luck. Now today I was looking at the 4 wire weatherpack connector that goes into the Opti and realized there was no sensor on it. I do not remember seeing a sensor that it could be attached to when I pulled the cap and rotor off. One of my questions is did that sensor fall off into my Opti by the trigger wheel? Is there supposed to be a sensor connected to that plug when you remove it? And my final question is if I order a new Opti does it come with that sensor? Any help would be appreciated. The car is driving me nuts right now and I would really like to get it running. Thanks. -Dan
Old Jun 14, 2004 | 06:30 PM
JDBlaze85's Avatar
yeah a new opti would be a good decision. it comes with everythin already. just plug in and go.
Old Jun 14, 2004 | 11:04 PM
The optical sensor module is what the connector "connects" to. Have you compared what you installed with this:
http://www.charm.net/~mchaney/optisprk/optisprk.htm
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
MJ_Z28
Aug 7, 2002 07:15 PM
