Results Are IN!!! Everyone Who Knows Datamaster LOOK!
Old Jun 13, 2004 | 10:46 PM
c0rey's Avatar
With the datamaster I found:
LOW TPS
LOW AC Coolent
Here is the file for everyone to look at to see what Is up with my car. Datamaster opens the uni File!!
http://www.domestic-street-scenes.com/blazin/corey2.uni
Old Jun 13, 2004 | 10:57 PM
I don't know what you have going on, but your TPS voltage and % looked whacked out and the O2s are too.
Old Jun 13, 2004 | 11:23 PM
c0rey's Avatar
hey man I have no idea either. I just put brand new delco 02s in. And replaced the tps about 3 months ago. The car is running really rough. Only trapped like 94 in the 1/4
Old Jun 14, 2004 | 09:00 AM
With the throttle at rest and key ON, you TPS should read ~.50v-.60v (you don't need the engine running to test). Voltage and % should increase linearly as you press on the gas pedal.
Old Jun 14, 2004 | 11:07 PM
HBHRacing's Avatar
after reviewing the data I found.
Low TPS voltage
High Idle
High IAC counts
Bank 2 lean 02
bank 2 LTFT adapting for lean
I sugested a stuck injector but after talking with corey he told me he had a passenger side header gasket leak. That would explain the bank 2 02 readings staying lean as well as the LTFT readings.
he is replacing that as well as a delco TPS (his last one was a cheep replacment) and I also suested a new IAC or atleast clean the old one and the throttle body passage.
I'm also wondering if somone messed with the idle setting befire he got the car
HAWG
Sep 25, 2015 11:41 AM
Bails098
Aug 17, 2015 05:15 PM
Boss002
Jul 24, 2015 10:47 AM
