URGENT HELP!!! Flat Top or -16cc?
Old May 25, 2006 | 03:11 PM
WeirdRich's Avatar
OK if you had read my post about metal beading getting into the engine, then this may make more sense to you...but anyways....
The machine shop needs to know what new pistons I want to go with before 9am tomorrow morning, so this has to be quick...
I had -16cc inverted dome forged SRP pistons in my car before (.030 over). The machine shop had to bore the grooves out of the cylinder walls, so now I need .040 pistons. So my question is, now that I need new pistons, should I go with the -16cc pistons or go with flat top -5cc pistons?
Heres the rest of my set up...
CC306 Cam
Crane Gold 1.6 SA RR's
Fel-Pro 1074 Head Gaskets
Stock Deck Height
Eagle Forged Crank
Eagle Forged H Beam 6" Rods w/ L19 Bolts
Cloyes Double Roller Timing Set
Milodon 4 Bolt Splayed Mains
Canton Oil Pan / Pickup
M55HV Oil Pump
Ford Motorsports 42lb Injectors
Racetronix Walbro 255 kit
58MM BBK TB
K&N FIPK
1LE Intake Elbow
High Flow MAF
CSI Electric Water Pump
160* Thermostat
Mail Order Tune w/ LT$ Knock Module
Old May 25, 2006 | 10:35 PM
blackztpi's Avatar
Re: URGENT HELP!!! Flat Top or -16cc?
hey rich. -5 for compression unless u want a blower
Old May 25, 2006 | 11:52 PM
WeirdRich's Avatar
Im not looking to go into a blower....just lots of nitrous later down the road
Old May 26, 2006 | 08:36 AM
MeanGreen97Z's Avatar
The neg 5 will bring your compression up but the shop may need to clearance the piston so they may come up in CC a bit. I'd definately do the -5s though.
Victor Lamb
Aug 26, 2017 02:52 PM
Countryboychevy
Jun 13, 2015 02:49 PM
4586
Apr 29, 2015 01:43 PM
KYWes
Apr 3, 2015 07:59 PM
pimpss96
Feb 12, 2015 01:28 PM
