Upgrade starter or not?
Old Jan 26, 2005 | 09:46 PM
SSmoked's Avatar
Well, it finally went. I got out of work and go to start my car to find my starter is bad. Luckly my boss had a hammer in the office. So before i go to AutoZone and get a reman i just wanted to know if i would be better off with the LT4 starter. Does the slightly bigger cam affect it? Thanks for any help.
Old Jan 26, 2005 | 10:03 PM
redcamaroz28's Avatar
Re: Upgrade starter or not?
Main reason for getting a high torque starter would be because of higher compression ratios. I'm sure with the cam you added a little dynamic compression, but that's nothing the stock starter can't handle. BUT, since it's already coming off, you might as well go with the Lt4 starter. From what I've heard they sound more "racey" and cooler.
Old Jan 26, 2005 | 10:27 PM
madhatter's Avatar
I have it. Mine went out, and since it is almost the same price from Vato Zone as it is from the dealer (or gmpartsdirect) I went for it. I believe I got it for about $155.
Old Jan 26, 2005 | 10:32 PM
Bersaglieri's Avatar
I did the LT4 starter after mine went hay-wire, sounds racey when you start it, like a quick spinning whine sound, pretty sweet. Also moves the solenoid away from your headers and their heat.
-Dustin-
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
