Unusual Starter Behavior (will not crank)
Old Nov 18, 2003 | 03:09 PM
wm_sorg's Avatar
I have an LT4 car that had a dead battery. After charging the bettery over night the car still will not start. The starter is making noise I have never heard before. It sounds like the starter is enguaging and disenguaging from the flywheel. It is almost like the clicking sound you get when the bettery is low but much louder. The rest of the car comes up fine. Is it possible the batter can not supply enough amperage? Anyone else experience this?
Old Nov 18, 2003 | 04:42 PM
BUBBA's Avatar
I'd say your battery is no good. A battery usually only lasts as long as its quaranteed.
Don't mess with a so so battery. Get a new one.
JMHO
Old Nov 18, 2003 | 04:54 PM
wm_sorg's Avatar
Does anyone know a good source for AC Delco batteries?
Old Nov 18, 2003 | 04:57 PM
97WS6SCharged's Avatar
I had a similar problem when I first got my 97 TA. Everything would cycle like normal, fuel pump, interior lights, etc... When you hit the switch, everything would die. Turns out, the cable itself was corroded internally (cheap POS). So, after getting a new cable and having the dealer install it, everything has worked fine and is still working good. Bout time for a new battery though, the original delco or whatever it is is still in there. Optima coming soon.
Old Nov 18, 2003 | 05:00 PM
BUBBA's Avatar
Many department chains sell Delcos for a good price. If you have the do re me, I'd get an optima red top. There are also good batteries out there that are pretty inexpensive. There are also some crap out there, so maybe some one here can give you another recommendation.
A good top of the line Die Hard (sears) is a good choice. There are some lesser touted brands that have also proven their metal.JMHO
Old Nov 18, 2003 | 05:03 PM
Hyperspeed97z28's Avatar
Get a wal-mart everstart or an advance auto battery, the warrenty with them is great, I think die hard's do excactly what the name is. DIE HARD!
Old Nov 18, 2003 | 06:59 PM
wm_sorg's Avatar
Thanks for the advice guys. I picked up an interstate MT-75 for a good price at the local parts store. I will throw a quick charge on it and keep you posted.
Old Nov 22, 2003 | 07:00 PM
wm_sorg's Avatar
Looks like the battery was at fault. I guess it delivered the volts but not the amps. Got another issue with a diag code now. Will post in new thread.
HectorM52
Jul 30, 2017 11:46 AM
Maroz28maro
Jul 29, 2016 07:45 PM
Knightscrapper
Feb 4, 2016 10:25 AM
surreybrad
Jul 5, 2015 10:36 PM
willismoons
May 27, 2015 04:03 PM
