Stupid autozone breaks
Old Nov 20, 2003 | 03:30 PM
Evilfrog's Avatar
Stupid autozone brakes
Last night, i noticed my rear brakes were grinding. Its only on the drivers side rear brake. IM pretty sure i bought new breakpads from autozone last spring.
Also, i think its only the outside brake on the driverside. And i can hear it grinding when i take off. Could it be my caliptor isn't letting go of the brake? I dont think i've changed snice i've own the car, and more then likely they are the stock ones....which makes them 11 years old now.Should i change them? and what are some good breakpads? Keep in mind i dont have much money.
BTW. My brakes skipped the squeaking the stage. I think the inidator break off.
Old Nov 20, 2003 | 03:38 PM
Ace_437's Avatar
They're brakes man, BRAKES.
Old Nov 20, 2003 | 03:39 PM
Evilfrog's Avatar
actually, they are broken.
AndyB's Avatar
BRAKES
Old Nov 20, 2003 | 03:40 PM
Evilfrog's Avatar
Originally posted by AndyB
BRAKES
Fine, i fixed it....anyone feel like answering the question?
Old Nov 20, 2003 | 03:44 PM
Ace_437's Avatar
Sucks when your brakes break, doesn't it?
Old Nov 20, 2003 | 03:47 PM
Evilfrog's Avatar
Brakes are suppose to brake, not break, now they dont brake and are broke.
Old Nov 20, 2003 | 03:52 PM
BUBBA's Avatar
Whatever the problem, don't let it ruin the roors/discs. Then you'd really be talking $$.
Tough BREAK!
Old Nov 20, 2003 | 03:53 PM
OldSStroker's Avatar
Re: Stupid autozone breaks
Could it be my caliper isn't letting go of the brake? I dont think I've changed it since I've owned the car, and more then likely they are the stock ones....which makes them 11 years old now. Should I change them? and what are some good brakepads? Keep in mind I don't have much money.
I don't think Autozone parts are the problem. After 11 years, it's way past time for a caliper replacement. It probably stopped sliding. Get rebuilts for both sides. Your cores are good for a trade in.
I like Performance Friction Carbon-Metallic pads, but if you want stock type, the calipers may come "loaded" with pads. Yours may still be under a replacement warranty. Check it out.
"Broken brakes" are a bummer.
BUBBA's Avatar
What the hell is a "roor"?
Old Nov 20, 2003 | 03:54 PM
Evilfrog's Avatar
Yea...um...know that we are done with the word games, should i change the capiltors or not?
Ace_437's Avatar
You could always break down and take it to a mechanic. Unless of course, you are broke.
Old Nov 20, 2003 | 03:56 PM
Ace_437's Avatar
What the hell is a "capiltor"?
Old Nov 20, 2003 | 04:02 PM
AndyB's Avatar
Re: Stupid autozone brakes
Did you buy them or just thought you bought them
Old Nov 20, 2003 | 04:04 PM
Evilfrog's Avatar
Re: Re: Stupid autozone brakes
Well, i changed either the front or back pads last fall. Then did the other set in the spring. So they both have been done in the last year.
People, I realize i can't spell.....no need to consently point it out. I miss Trey, at least when he was around people left MY spelling alone.
