Untuned ecu = red hot cats?
Old Sep 14, 2013 | 06:37 PM
ZX636RIDER03's Avatar
Hi,
Rebuilt my 97 camaro engine a few months ago and added a a bigger cam and ported heads. The previous engine had an LT4 hotcam kit which was tuned with 26lb injectors. Planning to upgrade the injectors to about 36lb and get this tuned eventually.
I'm noticing that the cats glow red with the current configuration. Is this due to the engine running lean or rich? Or is this just what to expect when running a bigger cam and ported heads?
The cam i'm running is a cc306, both of the cats are magnaflow.
Thanks,
Old Sep 15, 2013 | 12:54 AM
Fatdog2's Avatar
Re: Untuned ecu = red hot cats?
I gotta chime in.If your cats are glowing,this can burn your car to the ground.They must be clogged or something.This is a very serious thing happening to your car.I hope a moderator chimes in here.If not,do a search.If you park your car in the garage,you could burn the house down.It should make your car run sluggish or not run at all.This is a very important issue.STOP NOW.Get it checked.My02.
Old Sep 15, 2013 | 09:53 AM
Unclear.... you are running ported heads/CC306/26#/Hr Accel injectors without a tune.
In addition to the ability to burn your car to the ground, you are probably flooding the engine with fuel, diluting the oil, damaging the rings, and about to wipe out the bearings. The cam overlap is probably blowing intake air through into the exhaust, the PCM is seeing lean exhaust, and it's pouring in fuel the engine doesn't need. The fuel plus the blow through oxygen is burning on the cat, and about to melt it.
Your parts choices in and of themselves are prone to problems. The Accel injectors and the Aeromotive AFPR are known to cause problems.
Park it until you can get it tuned.
Old Sep 15, 2013 | 05:19 PM
Gotcha, that makes sense on why they would get that hot...I thought is was because of the header wrap that I put on the shorty headers. Now that I know this I'll keep it parked until I get the larger injectors and the tune. Wouldn't want to destroy all the time and effort that I put into building this.
The AFPR when I first got it was faulty. It ended up leaking and I ended up taking it apart and tightening everything down. That was about 8yrs or so ago, hadn't had any probs with it since.
Old Sep 15, 2013 | 11:43 PM
Many years ago one of our best-known members lost his 4th Gen when his oil soaked header wrap caught on fire.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
Mar 13, 2016 03:39 PM
Collector Car
Dec 17, 2014 01:12 PM
Dec 1, 2014 08:08 AM
