Unplugging Air Pump on 95' Z
Old Jun 27, 2004 | 10:02 AM
Eruption's Avatar
Exclamation Unplugging Air Pump on 95' Z
Hello all, I recently had some trouble with the air pump blowing fuses and triggering the SES light on as well as the engine fans coming on at the same time. I took the advice of past post's on here and unplugged the pump. This cured the problem of the light coming on but I am wondering what kind of effects this will have to my motor. Is this going to effect my fuel mileage at all? Thanks in advance!
Old Jun 27, 2004 | 10:27 AM
gb95zconv's Avatar
Fuel milage want be effected.....your engine will be fine. Your emissions will be higher at startup/cold .....thats the only negative.
Old Jun 27, 2004 | 11:22 AM
Peytons'z's Avatar
There was a recall on the air pumps on 95z. You may want to call your local dealer. I don't know much about what the problem was but the dealer told me they replace it under the recall.
Old Jun 27, 2004 | 11:56 AM
All true. The pump only runs at startup when the engine is cool and only runs for a max of 3 minutes or so.
Old Jun 27, 2004 | 01:40 PM
96ss2nv's Avatar
I've heard that if you still have cats, not using the AIR could cause them to clog up. Don't know for certain, though.
Old Jun 27, 2004 | 02:12 PM
irishz28's Avatar
the one and only reason that the air pump is there is to lean out the emissions while the car is warming up. So you are good, you could rip it off the engine and turn it into b0ng or some thing creative like that.
Old Jun 27, 2004 | 02:51 PM
Think about this: The Caprice/Impala had AIR pump problems, too. The GM fix for them was to remove the AIR pump completely (as in "no more AIR pump"). I don't think it would be a problem, knowing that emissions items are warranted for 8 years and the dealer would have to replace parts for free if they failed.
Old Jun 28, 2004 | 07:33 AM
Eruption's Avatar
OK, I won't worry about it then. Thanks for all the replys!
Old Jun 28, 2004 | 08:08 AM
gb95zconv's Avatar
Thats true....a few changes were made to the bin file in the pcm to keep emissions down when cold as well.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
