installing crankshaft hub
Old Jun 26, 2004 | 10:59 PM
lt1g3n's Avatar
what tool do i use to push this back on, i heard about getting a longer bolt from teh hard ware store with the same thread type, but im just too worried about doing that, every time i called an auto place near me to rent a tool , they direct me to the harmonic balancer remover, is this what i use? I dont see how it will put it back on..
thanks.
Old Jun 26, 2004 | 11:36 PM
Smokn '94 Z's Avatar
Make a tool like this...
http://community.webshots.com/photo/...66988851bOxMot
If the link doesn't work then look in my sig for the link to my pics. I have a pic of a tool I made using 7/16 - 20 hardend threaded rod and a matching nut with a plate drilled to accept the threaded rod and ran it home with an impact gun.. Took all of 5 seconds...
Old Jun 26, 2004 | 11:39 PM
lt1g3n's Avatar
damn thats sweet, i hope i can make one that will work without breaking stuff :/
Old Jun 26, 2004 | 11:55 PM
944v8inDFW's Avatar
I usually put a little oil on the hub and the sealing surface, crank too. Use the stock bolt without the stock washer and a VERY thin washer, lube threads and head, crank it down a few turns till the stock thick washer will go on the hit it with an impact and after it bottoms torque to spec. I have also done it without thin washer but be careful not to crank too much. DO NOT BEAT ON IT WITH A HAMMER
Old Jun 27, 2004 | 12:14 AM
lt1g3n's Avatar
i put a peice of wood over it and banged it a bit, lol about like 10 times, am i screwed?
Old Jun 27, 2004 | 12:19 AM
944v8inDFW's Avatar
Talking
You should be ok just dont wail on it with a hammer, next thing you do is miss and say WTF that hole doing in my timing cover? Maybe use wood to get it started then use a bolt or installer to finish it. I have seen many hubs and balancers jacked like 17 switches with a hammer. Uncle 944 says: Be Safe, Not Sorry. Cause JB weld can only fix so much!
Old Jun 27, 2004 | 12:21 AM
lt1g3n's Avatar
cool. yeah i think it'll be alright, i just dont wanna screw anything up its a brand new motor :O
Old Jun 27, 2004 | 12:24 AM
lt1g3n's Avatar
so i cant install the hub with the harmonic balancer tool o0 ?
Old Jun 27, 2004 | 12:30 AM
944v8inDFW's Avatar
You can install it as a set if you have it from your old motor. Either way is fine if you do a bolt or installer DO NOT and did i say DO NOT beat on the outer ring of the balancer. Just tap the hub and balancer on enough to get the bolt started. Then wrench it on. I usually use a 1/2 in impact gun set to about 1/2 pressure.
Old Jun 27, 2004 | 12:32 AM
lt1g3n's Avatar
well, i guess its too late for that, i banged it in enough to go in a bit, and then i figured it was probably bad so i stopped, and the bolt STILL doesnt reach the crank.. wtf
Old Jun 27, 2004 | 12:33 AM
944v8inDFW's Avatar
You take the thick washer off the bolt? You are LT1 right?
Old Jun 27, 2004 | 12:34 AM
lt1g3n's Avatar
also right now the damper isnt connected, its the hub, and underdrive pulley right now
Old Jun 27, 2004 | 12:35 AM
lt1g3n's Avatar
yes lt1, and i did take the thinkwasher off also ,still dont reach, i still have like 3 inches left of whatn eeds to go in =/ ..
scarey :/ im freakin out now, i cant estimate too well with inches, but thats the closest i can get without going outside and actually measuring :/
Old Jun 27, 2004 | 12:36 AM
lt1g3n's Avatar
damn im sorry for so many questions : heres a good one , what method is the way for lining it up correctly, i thought it was the bulged out line at the top of the hub, and then the indention in the crankshaft
Old Jun 27, 2004 | 12:37 AM
944v8inDFW's Avatar
You got a key in your crank? If so make sure it is lined up right. In the late LT1's no key. So pretty easy. If you have a key make sure it is seated equal. Like i said a litte oil does wonders for it going on.
