Unplugging Air Pump on 95' Z
Hello all, I recently had some trouble with the air pump blowing fuses and triggering the SES light on as well as the engine fans coming on at the same time. I took the advice of past post's on here and unplugged the pump. This cured the problem of the light coming on but I am wondering what kind of effects this will have to my motor. Is this going to effect my fuel mileage at all? Thanks in advance!
the one and only reason that the air pump is there is to lean out the emissions while the car is warming up. So you are good, you could rip it off the engine and turn it into b0ng or some thing creative like that.
Originally posted by 96ss2nv
I've heard that if you still have cats, not using the AIR could cause them to clog up. Don't know for certain, though.
Originally posted by shoebox
Think about this: The Caprice/Impala had AIR pump problems, too. The GM fix for them was to remove the AIR pump completely (as in "no more AIR pump").
stockssn2o
May 25, 2015 08:54 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
