Unknown vac line? Emissions?
Old Sep 28, 2014 | 02:56 PM
REDNECKISBOSS's Avatar
I have a 1994 z28. I bought it a few months ago and it needs a little tlc. There is a clear line with a spring/coil inside running from a bigger line that comes off the top of the motor. It T's off the big line next to the steering column under the hood. The guy before plugged it with a screw? What is this line?
Old Sep 28, 2014 | 03:20 PM
Re: Unknown vac line? Emissions?
Doesn't sound like anything I ever saw on my 94 LT1, and I bought it brand new. Might want to try and post a picture.
"New Member Introduction" doesn't get a lot of traffic, and isn't the best place to post tech questions. Let's move this to "LT1 Based Engine Tech".
Old Sep 28, 2014 | 03:23 PM
How do i move it? And i dont know how to post a picture. Sorry. Real new to this
Old Sep 28, 2014 | 03:45 PM
Kevin Blown 95 TA's Avatar
You got an automatic transmission?
Old Sep 28, 2014 | 03:48 PM
Yea. Its auto trans
Old Sep 28, 2014 | 03:56 PM
I'm wondering if someone at one time had that tube connected to a vacuum modulator kit that Trans Go sells? The kit replaces the pressure control solenoid in the valve body that is electronically controlled, and makes the trans shift off the engine vacuum like in the old days. For a while, people were doing this in an effort to try to get the transmissions to live, but then later better parts were available and everyone learned to build the transmissions better, so I don't hear of anyone using those any more.
Old Sep 28, 2014 | 04:01 PM
Does it look like this? You can see the tube with the springinside it which keeps it from collapsing form the vacuum
Old Sep 28, 2014 | 04:05 PM
I wish i new how to post a picture from iphone. But its kind of like that. But i dont understand why its spliced into the line going into the top of the motor?
Old Sep 28, 2014 | 04:06 PM
The line it splits off of runs from the top of the motor over to a round black box on the firewall on the drivers side.
Old Sep 28, 2014 | 04:08 PM
When the car is running it has suction
Old Sep 28, 2014 | 04:10 PM
That white T is the exact same t thats in my line. And the line is almost identical. The line itself is a lil dry rotted and has a split before the plug. Should i take the line off and plug the inlet on the T?
Old Sep 28, 2014 | 04:17 PM
I'll bet that's what it is. It is tapped into the brake booster vacuum line that goes to the intake manifold. Just get as much of it out of there as you can and plug it or cap it off.
HectorM52
Jul 30, 2017 11:46 AM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Jason Short
Jan 19, 2015 06:34 PM
