Unforgiving Cam and Emissions and you
Old Apr 18, 2006 | 08:03 AM
Heatmaker's Avatar
Advanced Member
Are there any tricks of the trade to make a giant cam pass emissions? I mean something like the GM847 type of specs.
Old Apr 18, 2006 | 10:11 AM
cjmatt's Avatar
Re: Unforgiving Cam and Emissions and you
i dunno if it applys to big cams, but on my old jeep i will toss a bottle of rubbing alcohol in the gas tank. always passes with flying colors
Old Apr 18, 2006 | 06:22 PM
96capricemgr's Avatar
You need GOOD cats consider keeping a pair just for testing., an "emmisions only" tune is another alternative if your tuner is willing to help.
Freshair pumped into the exhaust prefferably after the O2s.
Use a 180s stat and either set the fans high.
Old Apr 18, 2006 | 06:31 PM
BlackScreaminMachine's Avatar
GM847 with every possible trick in the book will not pass emissions. You may get it close, buts its going to be ULTRA hard. I have roller emissions in CT and I had a hell of a time with a hotcam and a 383, though mine was running rich due to a host of problems. I got it to pass.
If I were to try, i would do this.....
A BRAND NEW CAT as close to the manifolds as possible, either off of a shorty header or manifold
180 degree Thermo
Lean tune from your tuner
2 bottles of rubbing alchohol, in 93 octane gase
change roller rocker ratio, this will lower the overlap area in the cam lobes.
Old Apr 18, 2006 | 06:37 PM
97TransAm's Avatar
I went emission exempt...
rideordie
Nov 5, 2019 04:52 PM
TC94Z28
Apr 16, 2015 09:48 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Queens94z28
Nov 20, 2014 06:03 PM
RichJ
Sep 26, 2002 09:43 AM
