Underdrive Pulley Help
Old Aug 2, 2005 | 03:26 PM
miiso11's Avatar
When installing the crank pulley, does the hub stay on , then put on the new pulley, then the stock pulley/balancer?
I appreciate any help.
Old Aug 2, 2005 | 04:24 PM
Re: Underdrive Pulley Help
If its a "sandwich" type pulley, then that's the way it gets installed. You need to keep your stock damper. Check the length of the bolts that hold it all together, to be sure they aren't too long and hitting the Opti.
There are also "integrated" underdrive pulley/dampers that completely replace the stock damper, but that doesn't sound like what you have.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
