Two very stupid questions...
Old Feb 20, 2003 | 07:52 PM
MrZ's Avatar
MrZ
1. How do you tell when your clutch is going bad? This is only my second car with a manual tranny, and the first one had a brand new clutch in it, so I really have no idea how to tell.
2. At idle, my car has sort of a knocking sound coming from under the car right around where the front seats are. Anyone know what this is? Could it be an exhaust leak?
Old Feb 20, 2003 | 08:05 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Two very stupid questions...
1. it will slip.. it wont grab. your car will rev up a bit, grab, then the go normally
2. good possibility
Old Feb 20, 2003 | 08:11 PM
BOWTYDE's Avatar
1. It slips alot, when it gets really bad your tires won't spin off the line when you floor it. Also if you crusing in 4th or 5th and floor it, the engine will rev because the clutch is slipping.
2. The best thing to do is look. It is probly somthing loose. I have had alot of problems with the heat shield on my cat (which is right under the floor)
Old Feb 20, 2003 | 08:48 PM
Buttercup's Avatar
The best way to test the clutch is to throw it in 6th gear, find a hill, and give it some throttle. If the clutch is going it will slip. Also, problems going into gear may indicate a clutch problem.
Exhaust leaks tick, they don't knock. Does the car have an aftermarket Y-pipe or headers on it? If so, the Y-pipe might be contacting the heat shield or floorpan. If it's happening at idle it's not too difficult to climb under there and find the source
Sheesh, bring it down to Cathedral Square when I'm working and I'll look under there
Old Feb 20, 2003 | 09:21 PM
Mizz96Z28's Avatar
Does the knocking sound go away when you push in the clutch? If so then its the throwout bearing which I believe is normal unfortunately. Myles
Old Feb 20, 2003 | 09:27 PM
Buttercup's Avatar
The TO bearing is more of a rattle than a knock IMO. I know sounds are subjective but when I hear the word knock, I think of someone hitting the underside with a mallet.
Old Feb 20, 2003 | 09:30 PM
Mizz96Z28's Avatar
Maybe its more of a clunk? Or a rat a tat tat? who knows Everyone has there own words for sounds
Old Feb 20, 2003 | 10:38 PM
MrZ's Avatar
MrZ
The sound coming from the car at idle sounds something like when you knock on wood. It is probably nothing, I am just paranoid as hell about my car.
As for the clutch, today I was having a hell of a time getting it in 2nd gear for a while. But I played around with the shifter for a while and it went away. Again, probably just me being paranoid.
Buttercup - I don't know about crawling around under my car, but sometime I might have to get a hold of you to help me out with !CAGS....it is evil and it needs to die!!!
Travis
Old Feb 20, 2003 | 10:44 PM
Buttercup's Avatar
Travis
Travis, email me. I have all sorts of really good solutions... some that can be done in the parking lot at work, in Dubuque.
I can get rid of CAGS the "right" way
Old Feb 20, 2003 | 10:52 PM
treyZ28's Avatar
Travis
snycros?
Old Feb 20, 2003 | 10:59 PM
Buttercup's Avatar
Originally posted by treyZ28
snycros?
It's been cold up here, it's not unusual for the T56 to get a little notchy in this weather. Sometimes a good fluid change helps. Doesn't sound like he's driven a stick a whole lot either which might have something to do with it, just needs a bit more experience maybe.
I think he's just paranoid
The knocking sound needs to be resolved however. It may also be causing false knock problems but I could scan the car to make sure.
93 RedBird
Nov 15, 2015 08:24 AM
NewsBot
Sep 14, 2015 09:20 AM
cmsmith
Aug 9, 2015 07:30 PM
blkWidow
Apr 20, 2015 09:27 AM
