Turn-over problem
Old Jul 11, 2003 | 09:38 PM
ThrottleMonster's Avatar
Turn-over problem
I have this problem turning my 94 LT1 over. It turns over but it takes about a good 3 seconds of holding the key down and it chugging. Once it turns over ,about a second after, the rpms drop real quick but regain normal level just as quick as it dropped. After that it seems that the car runs fine. Im not sure if its my starter or if its my timing. Any help would be appreciated.
Old Jul 11, 2003 | 11:20 PM
Pandamonkey's Avatar
That's defintely a problem, I don't know about everyone else but I just have to give the key a slight flight towards start and the beast fires up. I'd say it would be a split second.
Sounds like your starter is doing it's job - it's trying to start the car.
Could be the timing.
Could be a clogged fuel filter.
Lets have some help here everyone - what other things could cause this symptom?
Old Jul 11, 2003 | 11:56 PM
93LT's Avatar
mine does this also. i would like to know too.
Old Jul 14, 2003 | 06:06 PM
Also , does anyone know how to do the timing on an LT1?
Old Jul 14, 2003 | 06:29 PM
flyinZ's Avatar
If I remember correctly, its in the PCM...you have to have a tuning device for that.
Old Jul 14, 2003 | 06:54 PM
NVetro's Avatar
I have the same starting problem, and the same year car, lol. A few ppl told me its prob the fuel pump getting tired. It all started with me after a 2 hour trip down the shore, will replace fuel pump eventualy, hehe.
Old Jul 14, 2003 | 07:10 PM
Toms30th's Avatar
I have a similar problem on my car but I don't think it's the fuel pump that's dying. If the fuel pump was going bad, wouldn't the car have trouble after start-up as well? Just my thoughts, I'm far from a mechanical whiz.
Old Jul 15, 2003 | 01:10 AM
scoobysnax83's Avatar
Not neccesarily... Do you hear it priming when you turn the key. Thats one sign... Best way is to pull out the old fuel pressure gauge and check to see if you have a leaking check valve up by the injectors.
Old Jul 15, 2003 | 01:34 AM
Yeah, i hear the fuel pump prime when i turn the ignition, as far as that goes.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
