Turn motor half a revolution then stops, whats up?
I just installed a new cam, and I went to adjust the valves and motor just stopped like it hit a brick wall. After that I ordered new springs to match the cam, and it is still doing it. I do have the oil pump drive out of the block, would that cause it. Or do you think valves are hitting the pistons? I wouldn't think it would be that because Iam running 14cc dish pistons in my motor. AFR 210cc heads on the motor also.
The crank gear, I put the arrow straight up. The mark on the timing gear I put straight down. I noticed that I put the locks on finger tight, and it looked like the pushrod was pushing the lifter all the way down. So I backed the locks off almost to the top, and the motor turns all the way.
formula79
26
Aug 5, 2002 12:21 PM
